mcyr
(Marcel Cyr, CMI)
December 28, 2013, 10:32pm
21
I agree David, I haven’t seen them yet in this area and when I brought it up 5 years ago on my own job site, they looked at me the same way and said what the hell is that. :)
mlarson
(Michael Larson, WI Lic. # 1672-106)
December 28, 2013, 10:47pm
22
I include a diagram that clearly demonstrates kick out flashings.
belliott
(Bob Elliott, 450.0002662)
December 28, 2013, 11:27pm
24
sfogarty:
Another example how some of you guys seem to loose your minds over something as simple as this. I never have seemed to be tackful and so if I offend you, dont look at this too deeply.
We can spin this one in any direction we want, and worry about the legal what ifs also. For me its real simple.
Every house I now inspect gets a recommendation for diverter flashings if none are present in certain areas.
Every house I can reach safely gets checked at these areas. I do the best I can.
I also don’t get on every roof either, I do the best I can.
I have learned in my area, that this is a common area for water entry, so I check these areas when its possible. If I can get to it safely it gets checked. If not, I still note the need for diverter flashings.
For the record I have also made new builders tear off siding completely, or remove areas because they did not tape windows or install house wrap at all.
Peeking behind the vinyl siding is not an invasive inspection. Seperating a section may be, but its part of my inspection. If I break a section, then I guess I will pay for it.
If you don’t know how to work with siding, then you should go work with a siding guy a couple of days. You should also know how the stuff gets put on or you have no business inspecting it. It is your job to say its done right, and not knowing how it can be taken apart is not knowing your job. Its siding, not rocket science.
Not getting on a roof, and then finding out later it was completely nailed on improperly, will get you sued as well, but hey you stuck to the sop
For the record, I scanned the interior wall with my thermal, and a moisture meter. No issues were found, and it appearantly was not severe enough yet. Once it would be coming through the walls, you would have a far bigger mess to contend with. Not seeking behind the siding would have far worse implications once discovered then standing on the ground just looking.
I bet a wall full of mold and wood rot would have your buyer hotter than a 2 dollar whore, but all would be good once you told them that your SOP’s did not require you to do an invasive inspection.
LOL you are so correct Sean.
Bet some of these same guys are afraid to lift a few acoustical ceiling tiles for fear of missing something where they did not lift.
Amazing !
It is cold here and one can be gentle to check for underlayment or moisture resistant barriers at the very least.
Just poor inspection not to do so.
mcyr
(Marcel Cyr, CMI)
December 28, 2013, 11:36pm
25
Bob, I do not make sense out of that statement, can you rephrase that?
canderson5
(Cameron Anderson)
December 28, 2013, 11:39pm
26
sfogarty:
First of all, Marcel just hit the ball out of the park with a single photo. That’s probably a $2 tool. Every inspector should own one.
Second, a $2 whore is not very hot, so that comparison is a little flimsy. That client would be hotter than a $400 escort!
Third, awesome, awesome post and thread. For those inspectors who want a first step to justify pulling siding, if the rain is recent but not immediately preceding the inspection, a moisture meter can also be a good, non-invasive way of finding these spots.
SOP is the minimum, like the codes we deride contractors for just barely following. It’s the least you can do.
canderson5
(Cameron Anderson)
December 28, 2013, 11:42pm
27
That makes you the first minority Member of the Year.
I love the look on a Realtor’s face when they get the concept of kick out right at the moment I pull back the siding and they see that big dark stain on the OSB.
mcyr
(Marcel Cyr, CMI)
December 28, 2013, 11:47pm
28
With no WRB because it is not required by local codes.
Huh!!
dandersen
(David Andersen, TN HI# 40)
29
With all that water staining from the upper roof down (in the video), you have to be on crack to not look under that vinyl!
BYW: I wasn’t really asking that question…
dandersen
December 28, 2013, 11:49pm
30
I wish I could post my report from today, but I suspect it will end up in litigation…
If you think it is happening, your 99% correct that it is or will happen.
Where is the thermal scan Sean?
You can do that one at noon, in the sun…
mcyr
(Marcel Cyr, CMI)
December 28, 2013, 11:56pm
31
Thermal scan required David, when you can see the damage visually?
cbottger
(Charley L. Bottger)
December 29, 2013, 1:31am
32
No not required but sure makes for good advertising;-)
belliott
December 29, 2013, 1:42am
33
mcyr:
Which part was difficult for you Marcel ?
Are you afraid to lift ceiling tiles if an area is suspect because I do not see you as that type .
mcyr
(Marcel Cyr, CMI)
December 29, 2013, 2:01am
34
The way it is worded does not make sense.
If you are afraid to lift ceiling tiles, how could you fear of missing something?
belliott
December 29, 2013, 2:49am
35
mcyr:
Marcel in H.I training classes they taught us not to lift any ceiling tiles as you would then be liable for lifting all.
We discussed this before but you most likely forgot as it has been a while.
They were always worried about liability to a insane level.
I lift them based on when I feel it is a possible discovery and could care less about liability if it means doing a good job for my clients.
I am out there trying to find issues rather than play Lawyer.
mlarson
December 29, 2013, 3:15am
36
I lifted some tiles last week. I hope that was OK.
belliott
December 29, 2013, 4:19am
37
Oooops…Liability is opened as you must explain why you did not open all now.
mcyr
(Marcel Cyr, CMI)
December 29, 2013, 1:07pm
38
Got you Bob.
I don’t lift them all either, just the ones that will reveal the most.
tsmith8
(Timothy J. Smith, CMI)
December 29, 2013, 1:29pm
39
I am not familiar with Tennessee but North of the border I would be very concerned with the lack of house warp. Do the Southern states not require it?
