sstaggs
(Shawn D. Staggs, CPI)
August 12, 2014, 7:59pm
#1
Hello,
I have a question, I attached a picture of the corrosion below. Do I write this up on a home inspection? I was wondering if it is any type of corrosion that will call any damage to the plumbing system.
Would I say, Plumbing pipe on top of the water heater was found to be corroded. Recommend further evaluation by a qualified plumbing contractor.
Just kind of asking around.
mlarson
(Michael Larson, WI Lic. # 1672-106)
August 12, 2014, 8:04pm
#2
sstaggs:
Hello,
Skip the evaluation by a plumber part.
Basically you need to write, It’s broke. Fix it and move on.
You might add, no active leaking at time of inspection.
sstaggs
August 12, 2014, 8:08pm
#3
mlarson:
Thanks,
So mainly is this consider to be lime scale build-up that can be brushed off by a wire brush. Just recommended to be cleaned?
mlarson
August 12, 2014, 8:10pm
#4
I don’t carry a chemistry set with me.
Note the corrosion, recommend service and move on.
Troubleshooting causes is not our job.
rlewis5
(Roy Lewis, CERTIFIED MASTER INSPECTOR)
August 12, 2014, 9:48pm
#6
Galvanic corrosion was noted. Recommend using dielectric unions
where dissimilar metals are joined (i.e. copper to galvanized).
mlarson
August 12, 2014, 9:51pm
#7
Unless you are in the habit of scraping away the built up corrosion, how did you determine it did not have dielectric pipe nipples?
rlewis5
August 12, 2014, 10:24pm
#8
I understand Mike, But that one is obvious.Huh ?
mlarson
August 12, 2014, 10:32pm
#9
Nope.
A small leak at the threads into tank can make the same mess.
rlewis5
August 12, 2014, 10:46pm
#10
Mike
Copper going into steel .
Can I ask you a question?
It may not be galvanic corrosion , but would not those nipples you posted do the trick?
Dissimilar metals?Huh ?
I think so.
mlarson
August 12, 2014, 10:47pm
#11
I can’t see any copper going into steal.
I don’t know what is under that mess.
Why speculate?
rlewis5
August 12, 2014, 10:49pm
#12
Go out and look at your heater.
You will see steal in most situations. Blue steel, they want them to deterator to sell you another.
mlarson
August 12, 2014, 10:54pm
#13
I repeat.
There is no way to know if a dielectric nipple is in place or not from the photo posted.
Do what you want. It’s your reputation.:roll::roll:
If you want to claim that, explain why it is only on one side.
I’m out.
rlewis5
August 12, 2014, 10:57pm
#14
It’s probably happening on the hot side.
Mike have you ever see Au do that?
growden
(Gary Rowden)
August 15, 2014, 8:50pm
#15
Yes I would write it up
“There is a heavy corrosion buildup on water supply line; even though there is no active leakage present at time of inspection, it can fail and leak at anytime and should be repaired. Refer to a plumbing contractor for corrective repair.”
dandersen
(David Andersen, TN HI# 40)
August 15, 2014, 11:06pm
#16
How do you guys know there is no leak?
It’ not going to be wet for long at 120F.
Same as Mike not seeing steel.
Don’t make stuff up you don’t know.
