Water heater woes
Originally Posted By: apeden
Water heater diverter woes ]
Originally Posted By: rmoore
Most of the water heater manufacturers make a direct vent model. Looks like that is an older State Industries model. Here’s a new one. http://www.statewaterheaters.com/lit/media/spec/res-gas/SDVG7-1-4.pdf
Should be something on the label/data plate about it being a direct vent model. And then there are powered direct vent models too...even more "diffferenter".
Go to the various web-sites (AO Smith, Rheem, Bradford White, State, etc) and take a look at the various models.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: dvalley
That vent appears to be a double walled vent (as Richard shows). As most w/h vents have a smaller diameter.
The outside channel brings in combustion air and the inside channel vents the gases.
David Valley
MAB Member
http://www.masscertified.com
