Originally Posted By: rdean
Would appreciate knowing if other inspectors call out discharges directly into floor drains? Technically, there could be cross-contamination if the
softener does not have a check-valve to prevent reverse flow!
I've never seen a setup when the discharge is mounted above the floor drain. Most are wedged into the grill to secure the discharge will flow directly into the floor drain. Comments please!
