Originally Posted By: ajalowsky
Originally Posted By: kdrauer
The Correct answer is Require 1 Square inch of vent space per 1000 BTU/hr input… is there sufficient evidence to change the question? Provide references please
Originally Posted By: gbeaumont
Hi Kay,
there are at least 3 potentially correct answers on this question
Regards
Gerry
Originally Posted By: Aimee Jalowsky
Which are…
A,C & D, maybe E as well
Personaly I would say the best answers was "taking combustion air from outside of the home"
Regards
Gerry
Originally Posted By: bkelly2
| gbeaumont wrote: |
Personaly I would say the best answers was "taking combustion air from outside of the home" Regards Gerry |
Originally Posted By: jferry
| bkelly2 wrote: | ||
Yeah. That's right. That's what I got, too.
| jferry wrote: | ||||
Yeah. That's right. That's what I got, too. |
That's great Joe, soon you'll be able to give up your miserable day job and become an inspector, right ?
Regards
Gerry
Originally Posted By: aleleika
| gbeaumont wrote: | ||||||
That's great Joe, soon you'll be able to give up your miserable day job and become an inspector, right ? Regards Gerry |
Ditto!
When you talk about direct vent you are talking about bringing the cumbustion air in from the outside.
And when you talk about 1sq in per 1000 btu, you are talking about How much cumbustion air is needed, not if it is a direct vent.
You can have a Category 1 furnace that is NOT a direct vent and utilizing indoor cumbustion air and that cumbustion air needed is still 1sq. in. per 1000btu's.
A. Dan Leleika
www.a-teamhomeinspections.com
Originally Posted By: Jay Moge
| aleleika wrote: | ||||||||
Ditto! When you talk about direct vent you are talking about bringing the cumbustion air in from the outside. And when you talk about 1sq in per 1000 btu, you are talking about How much cumbustion air is needed, not if it is a direct vent. You can have a Category 1 furnace that is NOT a direct vent and utilizing indoor cumbustion air and that cumbustion air needed is still 1sq. in. per 1000btu's. |
just wanted to see how many quotes in quotes will fit.
Originally Posted By: dvalley
oops
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: gmartin2
My understanding was that most direct vent units did not have standing pilots.
