This is a fitting (see pic) joining plex and copper. It just pushes together, no clamp, no adhesive. Is this a good way to make the connection?
Thanks
Rusty
Thanks
Rusty
See this:
http://www.pexsupply.com/CategoryPre.asp?cID=588&brandid=
and this:
That’s a fitting, nearly identical to the way the air lines connect for tractor-trailer brakes. They seem to work well in that application. :mrgreen:
Thanks my friend. You guys are good…and fast. The link was most helpful but I still don’t see how it works and don’t leak.
Rusty
This may help you to understand.
http://www.diydata.com/materials/plastic_fittings/plastic_plumbing.php
Thanks Michael, that was very helpful.
Rusty
Just stay away from electrical,or you will freak out on that site.
Not endorsing the site. It’s just where I found the cut away.![]()
It’s a U.K. site for those who have’nt seen it. 240 VAC, 50 Hz:-)
I have not seen “quick release” fittings for copper/pex, although they may exist. Check with a plumbing supply house.
I have seen “compression” fittings. Some use a “ferrel”. You push in the pipe/hose and then tighten the nut.
Are they similiar to compression fittings?
