This coil is on the main water line near the water meter. Can someone tell me what it is?
Thanks
Used parts from an old still???
My guess would be a homemade air hammer arrestor.
Thank you! Boy you are quick.
Its a warm up coil allows the water in the winter to warm up to room temp before entering the water heater unless someone is using a large amount of water then you get what you get
Wow, it is hard to believe there would even be a gallon in that coil, eh? :shock:
Heck Larry I have no clue I was just messing with those two guys that was making a wild A** guess so I thought I would also sounded good did it not;-)
Feeder for the icemaker??? (It’s a thin copper tube.)
Supply line for a dental chair?
The plumber forgot to bring his tubing cutter that day.
Gotcha…
or stiffed 'em & didn’t install the drain line
either way a useless waste
What is it connected to?
