Did an inspection and just curious what this mechanism is. I’m relatively new so this could be an obvious answer (just something I have not seen). Anyways it it a gas furnace (forced air) and this was attached to the outside of it (furnace was in garage). Looks like some type of timer with an on/off switch on the side of it (lower left) (sorry only one picture - thanks).
I’d guess some kind of duct damper/splitter control…
Larry’s correct, it’s a ‘make-up air’ controller. See page 57 of http://www.durodyne.com/products/durozone/durozone.pdf
Thanks for the help
Good link Mike (albeit a little large).
Robert…in our state we have regs known as VIAQ (Ventilation and Indoor Air Quality) http://apps.leg.wa.gov/WAC/default.aspx?cite=51-13&full=true .
Essentially it requires some means of drawing fresh air into newer “airtight” homes on a regular basis. In your case, it probably controls a damper on a duct to the exterior that allows fresh air to be drawn into the return plenum. On other houses you might find a “keyed” wall timer in one of the bathrooms or laundry controlling the exhaust fans (often combined with small vents at the windows).
Methods vary and can get pretty complicated and there’s really no way of testing the efficiency of these during a normal home inspection. Homeowners will often set these to absolute minimum times or, in the case of the bathroom fans, remove the keys completely as the fans coming on “annoy” them. Point the timers out to the client, explain the general purpose, and suggest they try to get the manual from the seller.
