what is this
Originally Posted By: jane molina
I found the device pictured below under the sink in a 12 year old house. It is on the hot water line leading to the dishwasher. There was no air gap on the drain line.
[ Image: http://www.nachi.org/bbsystem/usrimages/more/what%20is%20this.jpeg ]
Originally Posted By: tallen
Try again Jane. Your link goes to the home page.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Thanks Todd , sorry , hows this?
Originally Posted By: tvargas
The device is a water safety valve. It will not let water flow unless the machine calls for water. It is a back up to the installed water valve. The idea is no water can flow on a bad valve or a valve failure. I read the Miele manual after finding two of these today. BTW you must leave the dishwasher power on for the valve safety to work properly. There is a control cable inside the gray line containing the water line.
The manual also said that no air gap was required on the incoming water line because it was built into the dishwaher to prevent contamination of the City water. Our air gaps are to provide for prevention of contamination of the inside of the dishwater.
Tony
