Just when you think you have see it all…
The color of the shower curtain does not match the tile. I would write it up!
Good point…
Installed backward!
Or was the supply plumbing installed on the wrong wall?
Got a code for that?
I don’t know! Is there?
I doubt it.
What’s the problem?
It functions & drains…
Roy I received your text message but for some reason I couldn’t reply.
I was trying to send my “pics of the week”
The seller had a statue made like her dead husband. Freaked me out!
Here’s my tub pic - why the black water?
I think I was on Dickhead Circle!
Not often I drive to an inspection & see this
What a weird bitch!
Was it coming out of the spout or was the drain backing up?
I’ve see a lot of crap that comes out of the jets if hasn’t been used in a while.
The tub probably hadn’t been used for years metal plumbing corrosion getting flushed out of the line for the tub.
The manufacturer’s installation requirements might help.
Someone likely went through a lot of extra work to install that tub. ![]()
Well water supply, house vacant for a while.
My guess is the carbon filters are very very old & falling apart.
The water filter tanks were on the opposing exterior wall.
Was all the water like that? Did it stink?
I bet it smelled like rotten eggs. I see it quite often in high sulfur content water.
TG
Nothing wrong with that tub other than it is missing bubbles and a Female inhabitant.
How long did you watch for them? ![]()
Whenever I see black water, the water heater is full of H2S due to sulfur reducing bacteria. Usually a vacant house. Your nose will inform you before your eyes.
