Ok, new one to me. Inspecting a 8 unit flat roof 1920’s apartment. In the attic these wires keep getting in the way. They’re steel or copper, and wired up knob & tube style. Yet, a tic tracer shows nothing, and they are bare wire. They also just end at the wall.
Yes “thing” was wired with knobs and ceramic tubes… but without insulation, and in an odd pattern a few inches below the tar & gravel flat roof. The question is what was the purpose of that set of wires, and how do I determine if it’s still in working condition?
From what I understand doing some reading, some early K&T installations had the neutrals return by another route. This was later frowned upon because you need a complete wiring diagram to figure out what is what.
I’ve seen this a few times in the past and IMO they’re using the old knobs as a retrofitted grounding system.
Of course this practice wouldn’t fly today, but back in the day it was commonplace to ground to metalic plumbing pipes and route the EGCs the easiest and fastest way possible, which many times was through the attic.
Another possibility is that they were using them as cloths hangars on rainy days.
Runs like the one pictured ended, terminated, at a knob.
The wires are bare.
The wires form a pattern evenly spaced directly under the roof deck.
The attic has between 2 and 3 feet of clear space: it’s not for hanging anything, except for the needs of the most far out hippies for drying pot, later.
I can say 100% that knob & tube never used bare wires for neutral: that would be crazy unsafe as neutral in a split phase system can carry current. There were many generation of K&T, leading up to modern colored plastic wires. But all of them insulated neutral. And while neutral did use multi-wire branch circuit and even “carter” layout: the neutral: never would be done like this. Not a neutral. This building has perfectly functioning knob & tube, and the grounds are accounted for. That old knob & tube is bulletproof in my area: great stuff.
I will try to ask Charles E. Fisher of the NPS, author of:
50 PRESERVATION
BRIEFS
Lightning Protection
for Historic Structures
Charles E. Fisher
National Park Service
U.S. Department of the Interior
Technical Preservation Services
I have a feeling it’s something of a lighting protection system. It’s not however a lighting rod. The wire is #14, and not run how you’d run such a thing. It seems instead to be set up to collect stray currents under the roof or something.
Was it nonsense and hope at time it was installed, or an integral protection that even new roofs should have?
It was common practice to locate the conductor on the
outside since most systems were installed on existing
buildings. However, installations that ran down the
interior still were occurring. An 1847 article in the
Burlington Gazette refers to a church in Philadelphia that
recently was destroyed as a result of lightning: "It was
provided with a conductor, but it ran down from the
steeple inside the church!…. Such blundering ignorance
as that of setting a rod to conduct the lightning into the
house, we have seldom heard of.
I am leaning more to what Bryce mentioned. Older lightning protection wiring. Probably had a lightning rod on the roof and the wiring in the attic eventually led to a ground rod on the exterior. Just a WAG though…
