Does anyone know what kind of pipe this is? This is part of the main water line coming into a house right after the pressure reducing valve in the home. Home was built in 2016. It’s a gray plastic pipe with threads. Thanks for the help.
Looks like Schedule 80 PVC.
Check to see if your local ordinances allow that type of pipe in that application.
I agree. You can Google it and see by clicking images after Googling it.
Is that yellow CSST at the bottom of the first photo, (or simply an errant tag), and if CSST, why is it connected to the “water” supply??
It is just a tag
Its a polyvinal material
It’s a bit late but that’s a sprinkler pipe
Is the piping from the water main?
Look like a Zern Lead-Free Double Union Female CU SWT Pressure Reducing Valve for domestic potable water.
Yep. Probably didn’t want to use a galvanized or brass nipple.
