Can anybody help me identify this type of receptacle? I have looked online but cant find anything. Home is from 1958 in North Carolina.
Looks like a NEMA 10-20R.
Looks like Robert has the correct answer.
Thank you for the reply. Yes, it does looks like a 10-20R. Any recommendations on if or how it should be commented on in my report?
I wouldn’t comment on it in the report unless I saw a problem with it.
I would verbally inform my client that they could have an electrician convert it to a standard 120 receptacle if they wanted too.
A little odd for a residential installation. May have powered medical equipment? or some special purpose installation? (250v)
Thank you for your input. This helps me explain the matter to the client since they will likely be unable to use the receptacle for typical appliances.
I have seen them used to plug in big window mounted air conditioners.
was it located near a window ???
Yes, but the home has central heat and air. It was located in the dining room.
most likely for old window style cooling unit no longer in use…
We had one of those 240V 20A window units back in the 70s, and it was also in the dining room. After we got central air I ended up converting the 240V into a standard 120V receptacle.
they could push out a lot of cold air…
Morning, George. Hope this post finds you well.
As always, thank you for the illustration.
Would it be proper to refer to this receptacle as a Duplex NEMA 10-20R receptacle?
Your socket design predates NEMA, was made by Hubbell, and is described here:
This old socket be removed by the owner, sent to a museum. The wiring behind is likely fine, and can be used with a new socket.
The voltage rating of that receptacle was changed, it used to be 20A 250V, it was changed to 20A 125/250V, it is obsolete but had been used on 240V appliances in the past, the receptacles in Australia, & New Zealand use that design. Last one I came across was in the kitchen of a nursing home that I think was installed in a 1968 remodel, needed a 20A 120V circuit for a freezer & the wiring was able to accommodate that since they had supplied a unused neutral.
Yes, but I probably wouldn’t ever be that specific in a home inspection report. I would refer to it as a duplex receptacle and leave it at that.
