| Vickie Lewis wrote: |
| You've claimed you've done your job--that you aren't responsible for looking at appliances, understanding electrical codes, or knowing how old or what kind of condition roofs are in.
 If that is true, then your colleagues will tell me.  |
Okay ... As an engineer, inspector, and HI educator with over 20 years of experience I will tell you that is true, and the other inspectors were most likely just blowing smoke.
1. You can not tell the condition of an appliance unless you disassemble it, or it's obviously shot. Some inspectors check some basic things and that they work as a courtesy, but many just exclude appliances from inspections to avoid misunderstandings about the accuracy of any appliance assessments (and why most HI association guidelines exclude appliances).
2. Some HI's thoroughly understand electrical codes, but that is not the norm for most ... or expected of them.
3. You can NOT accurately tell the age of a roof just from looking at it. I have seen older roofing systems that were in unusually good condition, and then others that were not too old with premature failure (with age based on documented roof replacement ... not a guess). There are no manufacturer labels on roofing systems, so what are the other guys doing ... carbon dating the material. I dont think so. Sounds like blowing more smoke to me ...
It would probably be helpful for you to read the NACHI SOP also ... CLICK HERE ... and here is one from another national HI organization ... CLICK HERE. Notice that both exclude appliances, both exclude code evaluations (electrical or otherwise), and both say nothing about providing the age of a roofing system.
Sounds like you found an inspector who is just very straight forward, and not trying to blow smoke to impress you (or give you a false sense of security as to what they are actually doing) ... which doesn't do anybody any good.
Just my opinion and 2-nickels ...
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
