Originally Posted By: Monte Lunde This post was automatically imported from our archived forum.
When I saw the first two pictures, it was a no brainer. The third picture has now placed this panel Indoors, not exposed to the elements. I vote that this setup is OK.
Originally Posted By: rmoore This post was automatically imported from our archived forum.
In an odd situation like that, I doubt you could find any definitive code.
Jeff... as it appears that it's been there for a while, I suspect that your "gut feeling" includes an observation that the inerior of the panel isn't suffering from the location. Although we probably rely on "code" with electricty more than any other area, there will likely still be those few "gray area judgement calls" on safety and function. It is part of what we get paid for. In this case, as long as you feel it's a safe installation and is being adequately protected from the elements, I'd go with your gut.
-- Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Jeff,
You have a very experienced and knowledgable gut.  I, for one, would trust any judgement call you made.
-- Richard Moore
Seattle, WA
www.rainspect.com
Originally Posted By: dedwards This post was automatically imported from our archived forum.
This looks a a single unit, comprised of two separate doors. The thing I keep thinking is that it is clearly marked “for indoor use”. The outer door is hinged at the top so one could “assume” it was rated for outdoor use but it does not say that on the label. I hate it when someone comes along and makes a product like this that screws up the whole guidelines thingie and causes one to doubt what they know is right. It is almost a 50/50 call and like a lot of calls you could probably get 10 different opinions from 10 people.
Originally Posted By: lkage This post was automatically imported from our archived forum.
jtedesco wrote:
Quote:
See ARTICLE 312 Cabinets, Cutout Boxes, and Meter Socket Enclosures
312.1 Scope.
This article covers the installation and construction specifications of cabinets, cutout boxes, and meter socket enclosures.
I. Installation
312.2 Damp, Wet, or Hazardous (Classified) Locations.
(A) Damp and Wet Locations..........................
See Definitions Location, Damp, Wet
Joe, I would really appreciate it if you could go beyond pasting code refereces and say it the way you see it.
-- "I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Originally Posted By: bbadger This post was automatically imported from our archived forum.
From an electricians perspective this looks like an outdoor (Type 3R) panel that went bad and someone pulled out the guts and installed a dry location (Type 1) panel inside the old 3R enclosure.
IMO this could possibly be done code compliantly.
However I am very curious as to how the wiring was brought into the panel.
I would suggest having this checked into by a licensed electrical contractor.
-- Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Bob,
That was my first thought too until I read on the door label “combination cover”. I personally have never run across one of these but every time I think I’ve seen just about everything someone pulls out something that screws that theory up. The way the two doors are set up would aggrevate the crap out of me. I can see me holding the outside door up with my pointy head while trying to remove the interior dead cover (while ants and gnats chew on me).
My point would be to give a reference to a rule that covers the cabinet and its location which has been described by Jeff as damp. The panelboard is located in the cabinet and he can evaluate the condition of the equipment.
If there are any signs of rust or deterioration Jeff would be wise by noting that condition.
I have also added another thought for Home Inspectors to think about when they make this type of inspection.
It seems to me that we all learn something from each other, even when we only get to see a small image posted here.
lkage wrote:
jtedesco wrote:
312.1 Scope.
I. Installation
Joe, I would really appreciate it if you could go beyond pasting code references and say it the way you see it.
I was a little abrupt. My apologies to Joe.
What I appreciate, along with the code references, is the opinion of those with more knowledge about a specific situation posted here on the board. What would you do in the situation?
The more specific the better.
Thanks for the call Joe.
Galileo Galilei
Originally Posted By: rharrington This post was automatically imported from our archived forum.
Another take on it…
My thought is that "inside" may mean a conditioned space. One that is not suseptible to extreme temperature swings. The temp swings may occur in the set up here. Wasn't just thinking mositure.
I’m back (I’ve been working all day). . .
This was a load side panelboard fed from the service equipment. (you see the SE in the background of the third pic). 1999 build and identical on all of the neighboring homes.
There were 24, single pole 15 amp breakers and the interior wiring was very neat and workman like (sorry no interior pic).
Based on Joe's reference, however, I will defer this to a licensed electrician. As you can see in this pic, there has been moisture inside the cover. . .
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
