When inspecting
When inspecting a home do you only have to report defects only.
You should also report that items like the furnace, boiler, AC, water heater, sump pump, fireplace, disposal, ETC operated at the time of the inspection.
Short answer yes. But you need to indicate the inspection was completed in keeping with whatever SOP you are using. That means reporting good items to CYA that you were there and followed the SOP completely! You will want to describe many items that were not defective. The three important SOP words: INSPECT, DESCRIBE and REPORT.
INSPECT seems obvious but the SOP may tell you to report HOW you inspected a particular item.
DESCRIBE may be as simple as a photo showing a location.
REPORT typically means more than a photo as you will need to itemize the defect and suggest further evaluation or in many cases replacement with a description of the defects long term ramifications; house will collapse, burn down, injure the occupants. etc.
Is there a software or app to help to guide me thru inspections when getting started?
There are dozens of home inspection videos that Ben Gromicko has released over the years where he spends hours walking you through real home inspections. What I learned from him was the strategic use of photos in your reports for CYA , showing value to the reader so they see how hard you worked, showing limitations in the home, and for marketing.
Sorry I meant when I’m out in the field.
You haven’t given us much information about yourself. Are you in a licensed State? Have you joined InterNACHI? What computer phone will you be reporting on?
Generally what you want to do is determine what SOP you will be using. The two standard reporting methods are; room by room or system. Most inspectors use the system method. Your SOP will be itemized by system: Exterior, Roof, Plumbing, Electrical etc.
If you make a simple outline of the various systems that comprise your SOP you can then make subheadings for the different things required. This can all be boiled down to a simple checklist that you can take with you on your phone or tablet.
Some commercial software does all this for you and even allows for you to record, photograph your observations as you go along.
Many veteran inspectors, like myself, will then complete and polish the report at home BEFORE giving it to the client.
I’m in Florida and taking online classes for my license and I am a member with InterNACHI
What I did in Maryland was to copy the State Standards of practice and organize it in a more outline like form. I have both ,pdf and .doc forms (.doc (Word) is for editing, .pdf is for ease of copying).
People need to know what kind of piping (for example) is in the house whether it’s leaking or not. And so it is with a lot of systems, type of heat, electric service, type of siding etc. There’s no way to do a good inspection unless you tell them about the house you’re inspecting. So an inspection report is much more than reporting defects. You’re documenting the condition of the home when you inspect it. This documentation can come in handy in today’s sue happy culture…
Besides Defects, I have always went the extra mile to give my clients information that is helpful and not leave them wondering. Such as if water pressure was found to be normal, I will show that in the report, the same if there is a fireplace that Worked as expected. Your photos can also give them info they might find useful. A photo of the opened electrical panel(s), a few photos in the attic shows you were thorough. If you use a software that will allow 360 pictures… get a good 360 camera and use them in your report (impresses the heck out of people). If you want 5 star reviews you need to focus at least on Two Things. When opening the report they should feel you are giving them them more than what they expected (not basic cookie cutter check marks). The other thing which is almost always mentioned in my reviews is Communication…Answer your Phone, voicemail, emails and or texts ASAP, And always let them know you recieved their communications.
I use the old ITT terms, “Appears Serviceable” and “Operated”.
I report more than defects, but certainly most of a report is about the “bad” things. If the furnace is great, working as it should, or whatever description you want to use, then I tell my client it “Appears Serviceable.”
I note if the flooring is laminate or carpet, etc. I report if the kitchen counter is stone, or laminate, etc. I report if windows are casement, single hung, sliding, double pane, single pane, etc.
A 20 year old water heater or HVAC that is functioning properly at the time of inspection is not a “defect.” However, it goes into my report as a FYI that due to the age of the system and being past the normal lifespan for the system, budgeting for future replacement should be considered.
Afternoon, Boddy. Pleasure to meet you.
Thank you for that astute question.
For the most part, No: You need to describe the components within the systems, structures or components you are inspection be it defective or deficient.
InterNACHI SOP defines the scope:
Home inspection is designed to identify defects within specific systems and components defined by these Standards that are both observed and deemed material by the inspector. The scope of work may be modified by the Client and Inspector prior to the inspection process.
Let’s move deeper:
ROOFING: The inspector shall inspect from ground level or the eaves:
  1. the roof-covering materials;
  2. the gutters;
  3. the downspouts;
  4. the vents, flashing, skylights, chimney, and other roof penetrations; and
  5. the general structure of the roof from the readily accessible panels, doors or stairs.
II. The inspector shall describe:
A. the type of roof-covering materials.
InterNACHI SOP
Observation: Sloped roof. Shape: Gable. Plywood sheathing. No adverse conditions.
Three tab shingles: (Name defects/deficiencies) Various Lifted tabs. Various Nail pops. Tab Cupping.
Metal flashings: (Name defects/deficiencies) Dry cracked mastic.
Overall roof covering condition: No adverse conditions observed.
Just for clarity, Bobby, FL is a licensed state. In your case, you will follow your state laws and SoP. I am sure a FL member would be happy to post them here.
This is defined by the InterNACHI Code of Ethics. #10
  1. The InterNACHI® member shall comply with all government rules and licensing requirements of the jurisdiction where the member conducts business
Thank you for the clarification. Noted. The OP post did not state that.
I posted: For the most part, No:
