Hello, friends. I’m still in the learning phases here, can someone please tell me where the breaker in an electrical panel actually touches on the bus bar? There are two metal parts in the picture. One connects to the bus bar and the other is just to hold it? And what it’s being held to is metal? If so, would it need to be kept from touching other metal parts of the panel?
Thank you
The top “clamp” on the breaker in your picture.
Correct, the bottom “clamp” in your picture just holds it, unless it is a “plug on neutral” panel.
It needs to be kept from touching any “hot” (energized) metal parts in the panel.
Other styles may have a recessed slot for the buss connection and a plastic mounting foot, but they remain in the same locations.
Thank you very much! That is exactly the information I was looking for!
Scroll for various diagrams…
the rear fork is normally connected to the energized buss, and the front fork connects to a normally nonconducting metal bar or depending on manufacture and/or application can be part of the grounded conductor system.
What is “front” and “rear” to you?
Rear is the narrow end at wich the throw indicates “on” and the Front is the narrow end in which the throw indicates “off”. Throw being the correct terminology for the "handle/Swicth " on the overcurrent device. (i was sparkilly for 15 years )
Not sure what Larry was getting at but I would think the complete opposite. The bus connection is at the front and the conductor connection is at the rear. I guess either one is correct.
Sounds backwards to me.
That is my opinion also.
Think of the direction in which the current is flowing, looking at just the overcurrent device is looking at the middle of a stream, with the utilization equipment being the “end” and the Transformer being a “beginning” thus form our prespective the rear of the device is the entrence for the current “on” and the front is the downstream end and thus the "off’ position.
The current alternates the direction it travels.
yes but it comes in from the service “entrance” and leaves through the panel to the branch wiring. makes sense if you think that way.
I’ve seen many people where I wondered which was their front and which was their rear!
