Hey guys, do you remove dead-fronts with wood screws.
I know sharp wood screws can damage wiring and shock you so I wrote it up. I am doing the report right now though and it occurred to me that perhaps I should not have removed this cover. What do you guys think?
Yes and if when opening a panel I see there could be a close call I take pictures and make a report of it.
All dead-front covers should have approved machine screws with no pointed tips.
I remove the wood screws with a screwdriver then I write up the fact that improper screws were being used in the cover.
Depending on the circumstances, sometimes I will blunt the screws before putting them back, other times I won’t put the screws back or I may replace them with a proper type.
You are less likely to energize a screw when removing it, than you are while installing it.
That was meant to be a joke and I was not serious at all. LOL
No I do not tap them but I have seen them buggered up by improper screws.
It seems though that if I put a smile or a LOL it gets attacked anyways so I have given up.
