Any issue with this set-up?
200 AMP main service panel with 100 AMP breaker to first aux panel. 100 AMP aux panel has 60 AMP breaker to second aux panel. Thank you
I can’t think of anything right off. Typically, the load side equipment would both be 4 wire feeds.
Service entrance is 240V. Two hot one neutral.
I think he means two hot, one neutral plus the bare grounding conductor. All the subs are grounded to the main.
If the wiring has a homehandy look to it, I’d just note it as “amateur workmanship” and maybe advise a check by an electrician.
Yes, the neutral and ground are separated and the neutral is isolated at the subpanels, typically.
