Used the new 3D android app today for the first time. Works great, I have been using a windows pda but the android is a lot faster and easier to move though the inspection.
Only problem with the app is you need to upload each inspection from the home pc to the phone to have it ready. The windows phone I could start an inspection on it and go with it.
I suggest checking it out the program it is expensive but for me it is worth it.
Hi Leroy, I use 3D pocket PC with the HP Ipaq 210. Are you using Pocket PC or are you using the cloud with your Android? And if yes with the cloud, how do you like it?
To use 3D on Droid you must create an inspection on a laptop or desktop. You then upload the inspection to the 3D cloud. You then download the inspection to your Droid device. Open the inspection, perform the inspection, upload the finished inspection back to the 3D cloud and then download to laptop or desktop, polish it if needed and then print or send it off! Whole upload/download process is only a few seconds each way.
You can create and preload many inspections to your 3D cloud account at any time.
One of the best things is as you are doing the inspection you snap a picture of that cracked roof tile and it is inserted directly into the report!! No messing with picture insertion later!
The only problem I see that I would have is the battery life of my phone. I currently own a Samsung Charge & I can barely make through the day on a single charge - and that’s with sporadic use. I have serious doubts about it making it through a 3 or 4 hour inspection. My PDA can go 7 hours non stop on a single charge.
Get an extended battery. Check out Seidio brand as they’re the best. I can take my Evo out for an entire day without a charge where it only lasted 4 hours before.
Same here .
Got an extended battery last spring and went from 4-5 hours to all day and night on one charge.
Never used my second battery yet.
Makes it heavier but so what.
Is the 3D app in the market, or do you have to go straight to them for it? If its in the market can someone send me the link as I cannot find it. Can we test drive it if not currently a 3D user? I’m currently using AHIT’s Android app and while I like it and its functionality, it can get sluggish when you start bogging it down with photos. I am always looking for faster, quicker, better.
I still use 3D. I’m in the process of re-creating all my forms in HIP. I use a Lenovo Tablet in the field.
I have a docking station at home, so I never need to do any file transfering. When I return after my inspection, I put the Tablet into the docking station and finish up . My Desktop computer shares the monitor & Keyboard with the Tablet docking station…just hit a “Hotkey” and the Keyboard/monitor switch back and forth between the two systems.
