Originally Posted By: jremas This post was automatically imported from our archived forum.
What do you girls think about this one? Too close? What is the installation protocol from the EPA? This is a PA installation so the DEP would handle this.
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
Originally Posted By: mbailey This post was automatically imported from our archived forum.
Definitely too close.
I do not recall exactly what the EPA states off the top of my head ? but I remember all the diagrams in training showed the stack exiting the roof like a plumbing vent, and those mounted along the exterior of the house went above the eave/roofline.
The main part from the EPA was that it's exit point should be away from doors, windows, or other openings that could allow radon to re-enter the home.
Is the soffit vented on that home?
-- Mark Bailey
Stonegate Property Inspections LLC
Ponca, NE
AF103.5.3-AF103.6.1 wrote:
Termination at least 12 inches (305 mm) above the surface of the roof in a location at least 10 feet (3048 mm)away from any window or other opening into the conditioned spaces of the building that is less than 2 feet (610 mm)below the exhaust point.
You ever gonna get around to buying the IRC Jeff
Gerry, not only do I have a copy of the IRC 2000 and the new 2003, but I am also certified through the ICC and the state of PA as a Residential Building Inspector for the IRC. so there…
I often post things not for me but for others to learn from. I already know the answer. I thought this would be a good topic to learn from rather than the general crap bitching and moaning and conflicts on the board.
Seeya old chap
Jeff Remas
Originally Posted By: rwills This post was automatically imported from our archived forum.
This is from the Pa. Radon Mitigation Standards:
14.2.8 To prevent reentrainment of radon, the point of discharge from vents of fan powered soil depressurization and block wall depressurization systems shall meet all of the following requirements: (1) be above the eave of the roof, (2) be 1 0 feet or more above ground level, (3) be10 feet or more from any window, door, or other opening into conditioned spaces of the structure that is less than 2 feet below the exhaust point, and (4) be 1 0 feet or more from any opening into an adjacent building. The total required distance (10 feet) from the point of discharge to openings in the structure may be measured either directly between the 2 points or be the sum of measurements made around intervening solid obstacles.
Nos. (1) and (3) tells me this guy will be back out there correcting the problem!
