If you plan on buying a home I would recommend a Radon test for any home in northern Wisconsin. A Real Estate transaction is big ticket item and a simple radon test is good to do when purchasing any home or cabin.
Here is a picture of a radon mitigation system installed on a home. The problem here is that they used gutter material to form the stack pipe. It will work, but will need to be sealed very well. Dents can easily occur here. Schedule 20 or greater PVC pipe would be a better option.
I’m writing about the Radon Article for buyers and sellers. In it, it describes how passive sub floor systems are cheaper and easy to install for a new home buyer,rather than a mitigation system after a home is built. Passive systems can then be upgraded with an internal fan if the radon gases are not mitigated enough.
This is a photo of a radon vent pipe. The vent pipe may appear, at first, to be installed properly. The pipe is on the exterior of the home, the fan is installed vertically and the discharge opening is further than 10 feet from the window. However, the discharge opening must also be above the eaves of the roof. The installation of the vent stack is defective and should be corrected by a qualified contractor.
I read the article on back drafting, I though that it would compliment the radon course. In addition to depressurization systems there are many other causes for back drafting in a home, such as exhaust fans, dryers and improper installations. It should always be stressed to customers that they need proper carbon monoxide detectors in their homes, its not just old appliances that can be dangerous, back drafting can happen in brand new appliances.
I have always used Radalink for my continuous radon monitoring needs. The Aircat unit is bluetooth capabile, compact and user friendly. There lab provides an amazing looking, detailed and easy to read report for your clients. When it comes time for the units annual certification they send out a newly certified unit and you just send back the almost expired unit in the same shipping box.
Radalinks amazing service allows me to focus on other daily tasks of my home inspection business.
How a Home Inspector Can Stop Defamation.
Great article on Defamation and how to protect your name. Internachi provides information clips that you can easily insert into you letter. Be sure to have your legal department or attorney finalize before sending.
The manometer was installed. It indicated that the system was in operation. It also indicates that the system was operating the same as when it was installed. This is indicated by the black lines. It also indicated who had installed the system
The attached photo shows the vent stack pipe of an active sub-slab depressurization system, at the point where it emerges through the basement slab above the suction point. Also visible is the manometer-type pressure gauge, which in this case is showing a pressure differential of 1.2 inches WC.
The image in the InterNACHI gallery titled ‘Radon Decay Products’ illustrates the decay chain as uranium decays into radium, which then decays into radon. The health risk arises at this point because radon decomposes rapidly into subsequent decay products which also decay rapidly. These rapid decay events release alpha particles which can cause cellular damage in the lungs.
We have many research articles in this topic. Our company provides cheap writing services. Our prices start at $3 per page. 3 Dollar essay specializes in writing custom essays, term papers, research papers, courseworks, theses, dissertations, book reviews for English-speaking students all over the world. Our site is https://3dollaressay.com
This is an image of a Sun Nuclear 1027 continuous radon monitor. This particular unit was calibrated on October, 18, 2017 and will need to be re-calibrated on or before October 18, 2018. This unit can be used for short-term radon tests for both real estate and non-real estate]based tests.
damage-caused-by-radon.jpg- This image depicts radon gas and/or it’s radon decay products being inhaled by a human being. The most dangerous decay products of radon are Alpha and Beta particles. Due to their extremely light weight these particles usually only become most damaging when inhaled into the tissues of the human body.
In the graphic entitled “air pressure inside a home” we can see the many different ways that air pressure effects the way the radon particles can move within a structure and therefore the need to mitigate this unseen gas from conditioned space. It also helps with understanding why testing air within conditioned space is important.
In this satellite image of the america’s it is interesting to note the incredible amount of landmass that radon effects. Radon is a naturally occurring gas that forms as radium molecules break down. Radon can be found in any location however its intensity varies from one region to the next depending on the type of soil and rock found beneath the earths surface. Radon slowly permeates up from cracks in the earth and eventually makes its way to the surface. Thus, the type and nature of the ground determines how and how much radon permeates to the surface at different locations.
This is a photo of a crack in the floor of a crawl space of a 5 level split. The house is located in an area that predominantly has little radon. I would suggest to test it, just in case.
I have learned that radon is the second highest cause of lung cancer. Safe levels are below 4 pCi/L. Tests should be done if you are buying a home or selling a home. If you are buying and the home has had a test done in the past it is up to you to accept it or get another one done.
Gesture App Lock
App Faker
Pattern App Lock
FingerPrint App Lock
Speaks out the incoming contact name from call](http://www.uniqsofts.com/callernameannouncer/)
Speaks out the incoming contact name from message](http://www.uniqsofts.com/callernameannouncer/)
Speaks out content you copy to clipboard](http://www.uniqsofts.com/callernameannouncer/)
shake to unlock](http://www.uniqsofts.com/power-button/power-button/)
These two images are part of a moisture mitigation system. They’re installed in an unfinished basement. There is a crawl-space beneath the sub-floor of the basement. You can see the inline fan for this active system. No seal around that penetration is something to note. It seems a little odd they didn’t just integrate a radon system. The crawl-space has the required 6mil barrier with and gravel underneath.
Inspectors As Expert Witnesses:
In this article it talked about offering Expert Witness services. The qualifications one would need to become an expert witness included, practitioner in the subject at issue, an instructor in the subject at issue, and has published peer review articles, textbooks in his or her area of expertise. The article discussed how important it is to stay organized and concise when preparing for cases which involve litigation. My thoughts on this article are that it would be a good way to transition into retirement after a solid Home Inspection career.
