(I’m going to piggy back off of Kevin’s thread of a similar title)
I know, this should be in the WTF thread but I thought this one deserved one on it’s own.
I’ve never have seen this before.
Air handler installed in the basement inside the floor trusses. the only way to remove the unit is to:
Destroy the floor structure to pull it down
Cut a hole in the side of the house and slide it out.
Cut it out in pieces and put the new one in a different location.
Morning, Bert.
Hope your are well and in good spirits today.
Hydronic AHU?
You know the old saying; One mans ceiling is another mans floor. It all depends upon where you are standing.
I have seen many hydronic AHU package units in commercial settings in structural masonry building. Quite popular in my neck of the woods.
These Small hydronic package units, AHU, are tucked between a drop down false ceiling and the flooring above. Typically wedged between steel truss corrugated sheet metal with concrete on top.
As long as there is service clearance or a way to remove the AHU, I see no issues.
