wwilson3
(Wayne Wilson, TN 439)
January 29, 2014, 9:48pm
It been one of those ( here is your sign day )lol
rlewis5
(Roy Lewis, CERTIFIED MASTER INSPECTOR RETIRED)
January 29, 2014, 10:38pm
2
It looks like spaghetti , but where are the critical issue?
Other than a few doubles .
I’ll look again.
Roy Lewis
rlewis5
January 29, 2014, 10:45pm
3
I’ve been pondering this.
This service sub had 5- 15’s, 2- 20’s and a double 30 breakers.
It just doesn’t seem correct. But haven’t had time to check it out .
However , Those feeds look like #8 to me.
rhensel
(Russell Hensel)
January 30, 2014, 2:11am
4
I thought it was a Ground and Neutral on the same lug…
wwilson3
January 30, 2014, 12:27pm
6
Yes i was venting lolol why do they insist sticking the under the main lug
rcooke
(Roy D. Cooke, Sr)
January 30, 2014, 1:05pm
7
rlewis5:
WOW!!!
Its Magic ,
they have 15 white wires from 8 breakers .
they17 bare small grounds and
various large grounds and white wires too .
rmeier2
(Robert Meier)
January 30, 2014, 9:39pm
8
rlewis5:
How can you tell? Is that from photo #1 or #2 ?
rlewis5
January 31, 2014, 1:30am
9
Here is a complete pic. The electrical inspector passed it two day ago.
dhays
(David Hays, CMI)
January 31, 2014, 5:01am
10
So what’s the problem? You’re not adding up the breakers are you? That’s not how load calculations work.
dduffy
(Dale Duffy)
January 31, 2014, 5:32am
11
I see one of those a week, too…its not just limited to that side of the Mississippi…
rlewis5
January 31, 2014, 12:21pm
12
No problem. I would have used a larger feed.
But , that#8 is adequate for that sub.
It just look small when I first looked at it.
wwilson3
January 31, 2014, 12:35pm
13
Yes Dale it is a git er done moment 2 or 3 times a week . I was just getting tried of the complaining when we write it up. The old it has been like that for years routine.
kmcgrath
(Kevin McGrath)
February 2, 2014, 4:12pm
14
I do most all home inspections for the police officers of the Toledo OH dept
here is a 3000 sq ft home I performed an inspection on yesterday .
It’s a lil 100 amp panel with more issues than I care to address…
How do you like the Main lugs ?
They decided to feed a 60 amp sub in the garage with it …
Looks like she’s been damn close to combustion already .
two double taps in breakers as well, grounds and neutrals are all jammed together trippled up and plenty of loose electrodes in that bus as well…
She got a big RED note, and a recommendation for a new 200 amp installed asap !
kmcgrath
(Kevin McGrath)
February 2, 2014, 6:26pm
15
Look closely ! It’s a quad Tapped Breaker !
dduffy
(Dale Duffy)
February 3, 2014, 4:30am
16
kmcgrath:
I admit I’ve not seen anything remotely close to that mess in many moons.
mclark2
(Michael Clark, CMI)
February 3, 2014, 5:11am
17
I’ve never seen anything that bad, and I inspect remodels performed by “my uncle, an electrician in the coal mines”…
