… which did NOT stop the water from where it is getting into the hollow block walls
3:25 – 3:50 take a gander, efflorescence and she bring up the moisture meter reading
after a good rain, go ahead and do another moisture meter reading… there will be water IN the blocks
seller’s applied Drylok smh lol
this basement, like many others, was not ‘waterproofed’ by installing the interior system
exterior corner cracks here, block wall, cracks are not visible when one looks at the inside of this wall/corner, you won’t see any crack in the wall
