system
(system)
May 18, 2004, 12:00am
Originally Posted By: anatol polillo This post was automatically imported from our archived forum.
Fellow Inspectors,
Just got a new camera and had to try it today. So, is there anything wrong with this brand new panel in the garage of a brand new condo?
Anatol
(First time sending a picture, hope it is not to big)
http://www.nachi.org/bbsystem/usrimages/0panel.JPG
system
(system)
2
Originally Posted By: tallen This post was automatically imported from our archived forum.
Best looking panel ever posted on this board
– I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
system
(system)
3
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
Other than >6 breakers to shut off power? Is this the main panel or a sub-panel?
–Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
4
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
I see nothing wrong with this panel.
It might be set a little to deep but the cover is made to adjust.
What is on your mind, the lack of a main?
It must be somewhere else. (It better be anyway)
-- Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
system
(system)
5
He mentioned it was a condo I figure the main is outside by the meter.
system
(system)
6
You are correct.
No main and it passed with no problem. The builder will add it to his list. No gas shut off valve at furnace, water leak from main at slab…
The Plumbing inspector showed up while I was there and gave the place 3 violations.
Anatol
system
(system)
7
Anatol There is no requirement to have a main
at the panel.
It could be at the meter or anywhere between the meter and this panel.
-- Bob (AKA iwire)
system
(system)
8
Did not see it at the meter , nor was it visable anywhere in between. I have to go back to do the re-inspection and will find out what the deal is. The builder’s Rep had no idea where it was.
Anatol
system
(system)
May 20, 2004, 12:00am
9
Originally Posted By: Mike Parks This post was automatically imported from our archived forum.
Anatol
It is next to the meter.
And it MUST be identified. I mean it must show which unit it supplies.
Mike P.
