lolol!!@##@!@##@@!!!
caption…'I thought Aquaguard waterproofing was a reputable company…they subcontracted out the entire job to unlicensed sub,never telling me…perimeter drainage system is dysfunctional…here looks like cost $13,000+
More here
http://waterproofingadvocate.com/2012/12/11/what-we-contracted-for/
Sales inducement…
When asked about the accuracy of statements made by Aquaguard…‘every week they go out and LIE’ (yeah and so do 99.9% of these interior system companies…yep)
…Saleman touted himself as a ‘senior inspector’…lolOloLOlLLLL!! So much bullshtt man.
When asked about the accuracy of the forms, Aquadorks says…‘it’s outdated’. LOL!
See 2 sump pumps plus the dumb az interior drainage system/concrete torn up aong walls(mira drain bullshtt) plus friggin tar on the INSIDE walls, just another example of Interior shtt-breath,lying,incompetent,fraudulent companies.
Tell ya, anyone who continues to recommend SHTTT like this to homeowners is an assho LE! Got that? Got milk?
S C A M M M M M M M M M M M M M M M M M M M M M M M!
Yer consumers CHECKBOOK recommendation is fcd up, WRONG dude!!!
…'Don’t ask a basement waterproofing contractor for help until you are absoluetly sure you need one??? lol Eh…this is TRUE for any inside system scam-fk company sure but not anyone like my azz. Eh, please tell me just how many would SOLVE their g damn problem with out contacting SOME of us!!! Shtt, they’d likely run into the same shtt, call the same inside system azzholes even after they tried the DUMB az raising,sloping grade etc,bullshtt man! SO call, ask for help from…a home inspector? Really? lolol Most i know around here won’t find,identify the actual problem 'cuz they are simply not a fcg expert on this subject.
Send me yer complete modern guide to basement waterproofing, send it to my dumb azz, ill read the mfr THEN we’ll see whether yer full of SHTTT eh. Hmm, so NOW this dude is an expert eh, lolol!!!
Very very fkg tired of stooooopid incompetent statements aka SUPPOSED solutions/recommendations from quite a few who are NOT not NOT g dang experts on this g damn subject (no azz hole, you are NOT) incl’g many city inspectors, many realtors, some home inspectors…especially here in g damn Michigan(many applies here), media mfrs and so on.
Example, since quite a few homeowners have finished basements lets try this scenario…
finished bsmt,homeowner leaks/seeps at-along I-joint aka cold joint aka fcg cove in 1 or 2 areas. Some HI’s,many realtors etc will tell seller/buyer SHTT like, all ya need to do is raise/slope the grade and-or extend downspout extensions away from stoooopid house…WRONG ANSWER!!!
How could ANYONE say this, recommend this, BELIEVE THIS?!?!?!
Are you kidding! lolol
How can YOU recommend anything WITHOUT identifying the actual problem(s) SUCH AS,
how will raising/sloping the dumb azz GRADE or, extending downspout extensions 99 bottles of beer…oops, 99 miles away from stooopid house etc, how will THAT CRRRRAP fix,repair,waterproof etc the actual problems LIKE…
-a crack in the stoopid wall
-a open,leaky rod hole(s)
-1 or more openings,gaps around,above ground level like an open mortar joint or openings/gaps around,under,above a basement window,doors etc.
-a blockage,clog in lateral line
Ask again, please tell my dumb fcg azz exactly how ya’s figure recommending to homeowners raising,sloping the grade, longer downspout ext’s etc will fix,waterproof,tuckpoint,snake these actual problems!!! Fk!
I see/read this SHTTT on MANY HI websites and of course elsewhere, its fcg WRONG man.
Since when did you become an expert on this-subject.
The SAME example above goes for ANY INTERIOR SYSTEM company who ALWAYS recommends installing that bullshttt, regardless of the ACTUAL problem(s)!!!
Homeowner with finished bsmt has, lets say, one++ leaky open rod holes, water is ONLY seen at-along the FKKKKG cove,i joint…YET, these inside system incompetent clowns will almost always say,recomend installing an interior system,almost always with a stoooopid sump pump…and sometimes TARRING the inside walls!!! lolol
Same happens when there is an exterior crack,cracked parging on block walls…water is seen at bottom of wall-floor YET…inside system companies do NOT identify this, they could care less!!
Jesus KRIIIIIST, many homeowners have 1 area, 1 exterior crack in block wall, like a corner (see my stinky but real g dang photos), so…all they need is THAT small section done,waterproofed outside…cost between 1,000–1,200 most of the time VERSUS, NOT fixing that crack correctly from the outside and instead having some inside system company recommend and install an interior system, often w/sump pump that will NOT ‘stop’ the water from where its coming in!!! And, it’ll cost alot more than 1,200!!!
And a few FC-wads wonder why i get pizzed??? lol d i e plz!!!
Video, Unfair Sales Practice? Yes, yer g damn right it is!!!
http://www.indiananewscenter.com/news/in-your-corner/83022467.html
There has been at LEAST 3 home improvement radio talk show HOSTS (on air locally n likely fkg elsewhere) who’ve HIGHLY recommended these azz ho’s and some other inside system co’s who do the EXACT same shtttt! These PINHEADS get PAID from the inside system co’s to promote/recommend 'em, just like the BBB. NEITHER these hosts or the BBB is anything close to an expert on this subject and of course don’t do their homework on this shtt and blindly believe their every word plus, like i said and know, its all about the MONEY, getting paid regardless of homewoners getting fcd over. And they ALL profess to be every listeners best friend!!! lololol Eh, lolol, this alone may pizz off a few here…lol, at least 2 of these hosts are church-going, supposed HOLY azz…republicans! lolol
Perma Seal in Chicagoland…how could any supposed HONEST EXPERT ‘EVER’ get something like this wrong…huh
How many HI’s, realtors,dorks in the media recommend THESE terds
New Jersy piece of shtt inside system company
Hey pinhead Al owner of "We’re a piece of shtt water-diverting company and will fc you every chance we git’…eh Al, come to Detroit, yes duh Murder cap, have a few drinks with the good bros here man, come on,lets see how much YOU like getting fcd
Little Red Riding Hood
Little Red Riding Hood, eaten
butt, seems many do NOT ‘get it’ including some home inspectors eh, some HI’s here!!! LolOlololOllllllllll
