Your opinions are appreciated. What do you think could cause this roof to do this? Or do you think it is just a plain bad install by looking at the first two pics? I think the last pics just show the lack of flashing. Your thoughts? Thanks to those who reply.
The shingles look as if the nails weren’t long enough to hold, why it would lift like that looks like the flashing in that area is lifting or are those shingles and not metal in the transition area. Could have been that new gutters were installed also in that lifted up area. Or if they installed a new roof they may have been lazy and not insert the shingles under the gutter.
The valley is a poor job of a tight closed valley install or did they try to interlock the T locs some how? Never seen that done here in Colorado.
The siding is to close to the shingles and are you sure there in no step flashing that you might not have been able to see under there.
Any case trim the siding back and make sure there is step flashing and a GREAT paint job on the siding.
Hey Marcel,
Not sure what you mean by the masonite siding (12-8-6?) Composite siding like that is the most common around here. T-lock is also very common. Not so common where your from there in Maine?
I thought pics 4 and 5 should have had visable flashing to divert water away from the siding, especially from the fine job on the gutter above!? Your thoughts anyone?
