i been trying to inform peeps of this for a loooong time and been often criticized by morons, let’s see if the same morons criticize this video by Marko, a former home inspector
another thing lol, it’s apparently okay for others to ‘ramble on’ in videos but not okay for me to do that = more moronic dumb American crap
Marko’s video
2:20 — 3 days to back OUT of scam contract
5:40 - epoxy injections… he says, “Don’t even let these bastards in your house”
He’s right, as some of us have stated for many years.
And he’s correct that, what he shows in video, all that needs to be done per foundation wall is… waterproof the crack. Where i disagree BIG time is, one should not use epoxy and certainly not on the exterior of wall.
Some talk/act like epoxy injections are the best fix, NO they are not sheesh , i have witnessed approx 50% of ALL epoxy injections done on the inside, re–leak and almost all who sold that 50% fix to homeowners do NOT come back. Look, if a homeowner has a crack like this right where a front porch is, then sure, go ahead n try an injection on the inside but i warn ya again, some will last awhile and some will not.
In this video, one of our videos… same thing, a poured wall crack (plus OTHER exterior openings where water was getting in)
See the reinforcing rod in brick/mortar joint? lollll Water was getting in basement through this AND the other EXT openings… so doing an expoxy injection from inside a basement will NOT seal these hence, basement will still leak even after the injection to wall crack, duuuh!
The previous owner of this house had an injection done from inside basement and they slapped ‘bright wall’ paneling up against this section of the wall… duuuh, it kept leaking man!
IMO some home inspections should be much more careful when they only recommend epoxy injections for leaky cracks like this, why? lol Because they are not experts on this subject, that’s why eh… Why recommend a cheap,50% fix? I see other posts throughout this site where many HI’s recommend the bext fix for other problems, hence, they don’t recommend a 1/2 azz repair for those other problems
