Hi Friends
I got a request for inspecting 9 units apartment building, but only Electrical, Plumbing, HVAC for each unit, can I do it. I know it is limited to 4 units for full inspection. Please advise.
Thank you
Caleb
Hi Friends
Thank you
Caleb
In many (all?) areas, home inspection SOPs cover up to 4 units so above that you’re just like any other business performing a service. I generally use the same agreement which references the SOPs so I just perform the inspection like it is under them. The whole ala carte (plumbing, electrical, heating) thing is a hassle IMO and I really shy away from it. Just too much room for miscommunication. Say you go into a crawl space to look at plumbing and there’s a bunch of storm water…. I can just hear the phone call after they purchase. “You went down there. I just can’t believe you didn’t mention it.”
By the time I tailor my contract and report to what they want I could have just done the whole inspection.
MOST STATES… Classify Multi-Unit Residential as “Up to 4 units”, “Less than 5 units”, or “4 or less units”… (Yes the wording is EXACTING)! I think a couple of States use ‘5’ as their cutoff.
Regardless which number your State uses, all other buildings that exceed that number, such as your ‘9’ units (or 5 or more, etc.), are classified as Commercial Properties. MOST states do not regulate Commercial inspections, BUT some do! Don’t forget many dictate WHAT constitutes an Inspection, including multiple systems!
Also, assuming you carry Insurance, it most likely DOES NOT cover Commercial Properties.
You need to do more research than a question on a MB with no other qualifying information.
Good Luck.
Hi Matt
Your point is well taken, Thank you for your advise
Caleb
Hi Jeffrey
Great point about insurance, yeah, I need to be careful not do something silly
Thanks a lot.
Caleb
It is pretty much universal that once you have more than four units other (more onerous) laws and code regulations start to apply, including multi-dwelling emergency lighting and egress standards, ADA compliance, and, in California, specific balcony and deck laws, and so forth. So, I would only undertake a 9-unit apartment building as a commercial inspection.
I inspect rental buildings with hundreds of units. The city dictates how many units need to be inspected and what common elements are required and must also be inspected. These buildings need to comply with the IBC. Your 9 unit building is a walk in the park. Check with the local municipality to see what they require, it varies from area to area.
Note also that you are only doing an inspection of the HVAC, plumbing and electrical (do they operate, age, correct wiring).
Make sure your contract specifies exactly what you will inspect.
Did you do archive the InterNACHI commercial inspection prerequisite curriculum?
Are you covered under your professional liability & general liability insurance?
If your answer is yes to both of those questions, then are you capable?
So, to be more EXACT… (not that it matters beyond Scope and Feasibility), but… do these “9 Units” comprise the entire habitability of a single building, or only a portion of a larger scenario, such as ‘9 of 40’ units?
I ask, because if the Client changes the requirement to “4 units” to try and bypass the Commercial designation thus expecting a lower fee… your reply would be, “Nope, when purchasing the entire building/structure/complex, total unit count defines the Classification, NOT the number of units inspected”! It is common with large Commercial multi-unit complexes to only inspect a representative number of units (10-25%), although I often inspect a high percentage of available units, (often 50-80%, sometimes 100%).
Remember, depending on your location and local AHJ regulations, multiple systems (such as Electrical, Plumbing, and HVAC), may trigger/dictate your actions as being classified as a regulated inspection.
You should never me familiar with the COMSOP.
This is the ccpia commercial inspection sop.
But just doing the mechanicals it does not fall under any sop. It’s more like a commercial 4-point inspection.
Thank you William
Thanks, Robert. I’ll make it clear on the contract about the scope of work
I would begin with managing client expectations and work back from there. This will not be a “home inspection” but rather a system/component inspection on a multi-unit property, i.e. a commercial inspection. IMO, you need an agreement, a standard to follow (Commsop, ASTM, etc), an understanding of local laws, and a blessing from your insurance provider.
Thank you Brian, it is a good point.
Caleb
