Can you describe and identify the problems?
Can you describe what you see and identify the problems?
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: jpeck
Jerry Peck
South Florida
Originally Posted By: jhagarty
One Photo that continually changes.
Joe:
You may want to take a look at this and repost.
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: tallen
I do believe Joe is trying to tell us something.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: psabados
Hot deteriorated exterior wall receptacle.
Missing weather shield, non GFCI outlet, could be connected to GFCI breaker at the service panel.
A shocking awakening to all that may come in close proximity to. Male dogs and passing vagrants beware.
Paul
Counting down the days to Orlando 2005
Originally Posted By: jmyers
Looks to me like the face of the receptacle is completely missing. Not only is the face missing, it is not GFCI protected, a weatherproof cover is not installed and there is 118.6 volts waiting for the first sucker that will undoubtedly be electrocuted since they are most likely standing on a solid ground path (the earth for those that are not paying attention)! icon_biggrin.gif
Joe Myers
Originally Posted By: jfarsetta
I see death…
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Originally Posted By: Randy Flockton
The person conducting the test on broken electrical apparatus isn’t wearing proper protective equiptment (gloves?) I once probed a combo device (switch/outlet) with a hotstick which was simply missing the faceplate… The switch & outlet were wired for 2 separate circuits for a potential of 240V between 2 close together terminals… a glowing fault occured somehow & let loose with so much heat that my hand was slightly burned & carbon coated from the arc even at the distance of the hotstick! Taught me a little more respect for the unknown! icon_eek.gif icon_eek.gif The breakers in the recently installed Murray panel didn’t trip either… The terminals vaporized!
-Randy
"Prices subject to change with customers additude"
