system
(system)
October 4, 2005, 12:00am
Originally Posted By: senomoto This post was automatically imported from our archived forum.
http://www.nachi.org/bbsystem/usrimages/P/P1010231.JPG ]
– Stephen Enomoto
Horizon Home Inspection LLC
“You expect the Best . . . We’ll provide no Less”
system
(system)
2
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
If a receptacle is 12" below the counter it is not serving it.
system
(system)
3
Originally Posted By: srowe This post was automatically imported from our archived forum.
This has been a question that I have tried to get an answer to for a LONG time!!!
Thanks GREG!!!
system
(system)
4
Originally Posted By: bbadger This post was automatically imported from our archived forum.
GFCI answers are tricky as they are
always changing.
My answers are based on 2002 and carry over to 2005 NEC.
All outlets that serve dwelling unit kitchen counter tops must be GFCI protected regardless of the sink location.
To find what outlets are considered 'serving' the counter top you can look at 2002 - 210.52(C)(5) which first says
Quote:
Receptacle outlets shall be located above, but not more than 500 mm (20 in.) above, the countertop. ........
But then there is the exception which says
Quote:
receptacle outlets shall be permitted to be mounted not more than 300 mm (12 in.) below the countertop.
-- Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
system
(system)
5
Perfect…thanks again Greg and Bob.
system
(system)
6
I appreciate the info, but this still bothers me some how.
The outlet on the opposite side of the pony wall is in closer proximity to the sink than the outlet on the other side of the room 6 ft away from the sink.
Would you not write it up at all or would you mention it as a possible safety issue?
-- Stephen Enomoto
"You expect the Best . . . We'll provide no Less"
system
(system)
7
You could write it up as a recommendation for added safety but if I understand the layout it is not an NEC violation.
– Bob Badger
Moderator at ECN
system
(system)
8
Originally Posted By: jschwartz1 This post was automatically imported from our archived forum.
– Jay Schwartz
Coast To Coast Home Services, Inc
www.Coasttocoasthomeservices.com
Southeast Florida NACHI Chapter - VP www.floridanachi.org
NACHI - Legislative Committee Member
MAB - Member
