Originally Posted By: rmoore This post was automatically imported from our archived forum.
Anyone got a feel for the age of this oil-fired FAU. 1913 home. No data plate and only the name “Mayflower” on the front. Might be the manufacturer or the boat it was shipped on. It appeared to be in good working order, good flame color, liner etc and has been serviced on a very regular basis. How long would you expect the heat exchanger to last on a dinosaur like this? Also…I could not find the filters either in the return plenum or the return registers but there was a note that they had been changed this year. Any ideas where they might be?
-- Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: jsavino This post was automatically imported from our archived forum.
Richard
I'm sure you checked inside the rear hatch of the blower unit compartment. That where I find them. Or maybe some one is fibbin about changing them.
I like the new smoke elbow all shinny lookin.
Originally Posted By: dvalley This post was automatically imported from our archived forum.
Robert,
I've inspected several of those huge ships. You know what to tell your client when you see one of these.
The filter is always located on the opposite side of the burner access door. Right inside and under the return ductwork that penetrates the cabinet. If there?s no filter inside that door, then it's missing. Check for diagonal tracks on the sides of the cabinet that hold these filters in place. There are usually two filters inside the cabinet. Sometimes they are the same size, other times they are of varying sizes.
Originally Posted By: kluce This post was automatically imported from our archived forum.
Looks like the Thermoflo oil furnaces I use to condemn about 15 years ago. A lot of oil furnace were around South East Wisconsin 15 - 20 years ago.
Still has the stack primary. It doesn't look like it has an air conditioner with it since it has a reg. at the plenum. There is different ways to handle this but I normally take the reg off to look at the heat exchanger. A lot of these heat exchangers crack at the top where it's most heat build up.
I still recommend further avaulation by a heating tech.
kluce wrote:
What did the tag say right above the handle to the burner?
Nothing legible Kevin. There was a small data plate on the opposite end. Only thing I could get from that was the input BTU (100,000).
I don't remember the tracks inside the air handler but they may have been there. Probably concentrating too much on the fire-breathing end of this dragon.
-- Richard Moore
Seattle, WA
www.rainspect.com
Originally Posted By: mberman This post was automatically imported from our archived forum.
i say late 50,s early 60,s also check the flue tube going through the blower compartment sometimes pitted at bottom.as stated earlier the air filter should be in the blower compartment (somewhere}.-------matt.
The earliest legible entry on the inspection/service stickers was 1969 but there were a few before that that I couldn’t make out. So very early 60’s or late 50’s makes sense. I ended up reporting it as “likely more than 40 years old” along with the usual recommendations.
Thanks guys...I'll be better informed if I see one of these again.
BTW...in the photo to the right of the furnace you can see a bunch of clay (?) pipes on the cripple wall. These were about a foot long, maybe 3" in diameter with about a 1 1/2" bore. No clue where they came from or what they related to. Any ideas?
-- Richard Moore
Seattle, WA
www.rainspect.com
Not sure Kevin, but it wouldn’t surprise me if it was a footprint from the old coal or wood furnace. One corner of the basement looked like it was once a solid fuel hopper.
Water heater is sitting on an insulating pad...and NOT seismically strapped.
-- Richard Moore
Seattle, WA
www.rainspect.com
