Found this on the top shelve in the shed that was long forgotten I even had it. Been in the shed for at least 30 years and belonged to my father back in the 50’s.
I will need to refurbish it a bit.
when You get that one cleaned up You can work on mine partner, It could use a little work…
This is what so called “craftsmen” use today ![]()
That is old Bob. What year does that go back too?
Before I was born.
30’s, 40’s maybe? (John Deere is a little more recent)
If you can’t plug it in or put gas in it I don’t want to play with it.
Nothing wrong with the old one you found. That combined with a good coping saw, good work can be done.
I have a tool if you need to make the molding you want to miter.
You’ve got a gem there Marcel!
I cleaned mine up, polished it, had it sharpened, slicked it up and sold it at a garage sale 5, or so, years ago for $1,200.00. ![]()
No one around here would pay that kind of money. Like Bob said above, if it don’t plug in or use gas, they won’t touch it. I can’t even sell this 1970 Rockwell for $15.
They don’t make them like that anymore either. Internal motor grounded to the steel case probably so you can get zapped when cutting wet wood. I had a similar saw from the late 60s, don’t recall the brand, but you had to wear gloves when cutting anything with a higher moisture content or you’d get bit when you pulled the trigger. LOL.
You definitely needed a grounded extention cord, but when the cord got wet, you still got sapped. No GFI’s back then either. Plug it in and go. Also had those 14/2 with ground flat extension cords.
had an old commercial 8" about threw me off a roof once, cutting in vents off of jacks and planks, as I recall I chucked it a good distance off the peak of that roof…
Used to drop them in a hurry, that is for sure.
I have several all metal case drills, including a 220v all metal two handed monster. Plastic is so much lighter, of course the batteries keep getting heavier! LOL
Bob, those big ones were arm breakers when they bound up, they kept turning after you let go the switch.
Got one in my shed also. Still works and I am pretty fast with it. But I am an old fart.
Hell, send it to Larry and spit the profit
