What would be the write up…I need help with verbiage.
David
http://i187.photobucket.com/albums/x296/dawlita/Nachi/100_7147.jpg
David
Are you serious!!! all I would say is get a bucket under it and empty every day, or fork up some money to get a pump and extend it to a drain. LOL
I need professional verbiage…
I’m with Kevin, I don’t see it being too much of a problem it’s in a garage. You might recommend that the condensation piping be plumbed to exterior or drain system.
Condensate from AC discharges onto Garage floor .
Condensate pump recommended to remove water to a drain .
Roy I was just going to post a half page narative just for fun. LOL
You guys are only worried about condensate?
What about it being not sealed off with a self closing door from the rest of the garage.?
I just answered the question .
I have no idea if it has the correct size feeds or is it the correct size or how old it is… I expect there could be other concerns too.
Thanks everybody…I got the verbiage I need.
Ya need a better pic what I see is the secondary drain draining on the floor as it should if the primary drain is stopped up. It appears to me the primary is going behind the furnace am I seeing this correctly. Did I say need better pic’s
Since when is a HVAC unit allowed in a garage?
You guys are only talking about the condensate line.
Am I in the twilight zone?
This is quite common to have HVAC unit in garages here in CA.
I inspect 40% in garages, 40% in attics and the last 10% in hallway closets
Ducts
The 2006 edition of the IRC states the following concerning ducts that penetrate garage walls*and ceilings:
R309.1.1 Duct Penetration
Ducts in the garage and ducts penetrating the walls or ceilings separating the dwelling from the garage shall be constructed of a minimum No. 26 gauge (0.48 mm) steel sheet or other approved material, and shall have no openings in the garage.
Gas appliances are not allowed in residential garages, unless
the following conditions exist:
It is an auxiliary drain. It is supposed to be “conspicuous”!
It is an up flow, so air blows out, not sucked in.
They can be in a garage as long as the duct is 26ga metal.
Let it go…
Hope it is taped well and 26 gauge then.
Interesting model with a single cover .
Not familiar with it.
Assume it is a mid with inducer.
Yes, I write them up every week.
I would recommend that the drain in question be removed and plugged.
There is no need for it.
The unit is in the garage and an aux. drain is not required. It will just drain all over the floor anyway if there is a problem…
That pipe blows air out of the house which means the house is sucking air back in from somewhere. If it’s the garage, it’s a problem.
I thought chicago was the twlight zone Bob you really must get out more;-)
Get out plenty and there is much more to do in Chicago than middle of nowhere or wherever you are…lol.
Heading out with a couple people for a bike ride along Chicago’s beautiful lakefront in just a bit while you look at …pigs?![]()
Come check out the city if you are not afraid to be around actual people sometime.
Big festivals every weekend,art,music,best food in the country,pretty women,a downtown that is actually walk able and clean,major sports teams,shopping,parks and forest preserve,fishing,casinos,all minutes from the door.
What you got?..oil pipes…![]()
Does not communicate its heated
air to the rest of the building.
This is a bit confusing and deserves an explanation. I think David is right as long as both the return and supply do not communicate the heated air within the garage. No supply and no return is allowed to be in the garage but can pass through the garage if it is 26 gauge and sealed with fire stop.
Pretty woemen HUH I heard they were all transplants from Arkansas with no teeth and they are so ugly they make a freight train take a dirt road.
Thanks anyway but I prefer the quite simple life where everyone has oil money in their pockets :D:D
