Multiple Furnace Drainage
Greetings HVAC and plumbing aficionado’s,
Just out of curiosity, has anyone recently observed a residential mechanical room with two mid-efficiency furnaces burning natural gas and both draining very little (but obvious) excess condensate into the same floor drain, which appears to be a city storm tie-in?
How common is that?
The floor drain is a perfect place for those furnace condensate lines. It should be draining into the sanitary sewer not the storm.
No, do you have pictures and models of these units? It’s not normal for mid efficiency gas units to have condensate drains. Do these furnaces have AC coils?
He has obviously miss identified the efficiency of the furnace. Condensate lines should be ran to the floor drain.
Good call, they are both rated at 90%, but no AC in the furnace or plenum.
Thanks eh
So now I have to ask, where did you get this city storm tie in idea from? Do you understand what that would entail and how illegal that would be :laughing:
Aha yes I suppose that’s a lot of work to perform under the radar. Forgive my unknowledged slang
