Not really directly HI related but I learned something I thought I’d share - Our washing machine is nine years old and we inherited it from the past owners when we bought a couple years ago. I’m pretty sure the filter had never been cleaned. My office is right around the corner from the laundry room and when the washer was running I started to notice a nasty smell. So, after a bit of “Googling” it turns out modern-day washing machines have filters that get all gunked up and start to stink. I should have taken a picture of mine but this one I found online is about what it looked like.
Different machines have different levels of complexity to access and clean the filter but it usually fairly easy. Of course, the YouTube video I found didn’t turn out to be my machine and when pulling the appliance off the wall and taking the back off I found that the filter is actually accessed from the front. However, removing the front looked like a crapload of work (control panel, door gasket, door hinges, etc.) so I just struggled a bit and did it from the back. The key is to be ready for how much water comes out when you remove the filter (turn off the supply, of course). I probably got around a gallon. Since I was going at it from the back I actually unhooked the rubber hose going into the pump as it was an easier place to put a pan than where the filter unscrews but in most cases you just need a low-profile casserole dish or similar.
Anyway, I can’t believe the difference it makes getting all the nasty hair and general crap cleaned away. I think it’s a byproduct of the low water usage of these newer washers. They recirculate a lot of water and run it through the filter. I imagine my clothes are getting a bit cleaner too.
