These are real nice!!!
what was the problem? LOLOL you never loose your ball . It will always be in the middle
Unacceptable
Did they pull permits?
Do it right the first time?
Recommend ripping off all decks and using wood as firewood in the new chimney/fireplace that needs to be constructed.
The undersized joists and joist hangers are very scary. I would not let my cat walk on those decks. Wait, I do not own a cat:mrgreen:
Bad idea as it likely contains Arsenic which is not destroyed by the fire.
That’s a good quality item Clark!
LOL!!! You should see the inside!!!
