So much power in main panel box (basement) but coming into the house I think I have only 60 AMP service (garage)? I think I missed something.
Please help!!!
Please help!!!
Not enough information to make a determination.
I think this home inspector missed his electrical class | More schooling required NOW
What the hell did the fuses say on them (out of photo), or the actual size of the SE conductors?
Sorry I should explained myself better.
This part I don’t understand, but maybe with someone experience might help me. Then the main wire goes under the garage and breezeway slab and into the basement. The main panel box has a number of problems. However the main wires going in are 100/120 and 220/240. In other words 3 wires, two 100/120 and a neutral. 220/240 circuit are in use (stove, etc.).
Is this possible.
Yes Mr. Cooke, I did take the standard electrical course and passed. I joined in March 2018 to get up to speed with the rapid changes in this field and to get experience from fellow inspectors such as yourself. Thanks for your input.
Yep and you still did not tell us the fuse size .
Correct 60 amp fuses it is a 60 amp service .
Based on your second post you have a 60 Amp service.
The wire gage of the wires and conduit that connect to the overhead wires determine whether you can upgrade to 100 Amp within code. If the conduit to and from the meter box is one inch and wires are #6 you are stuck with it being a 60 Amp service.
And it does like that is the case.
A few observations:
