Okay this is a two year old composite shingle roof over a 21 year old asphalt composite shingle roof. My question is? None of the plumbing vents, skylights, or either chimney has visible flashing or sealant on the second layer. Is this practice acceptable? Was the thought process that the first layer was sealed so this layer doesn’t need to be? Somebody help please?:?:
This is one of the reasons double layering shingles is frowned upon. It is now harder to flash boots like these, and any flashing mistakes made on the first roof still exist. The rubber (neoprene) continue to degrade, and leave a weak point.
Simple question James just wanted to know what the actual code was. I am property inspector and I don’t do codes. Thanks though. Yes Michael it is a mobile home.
Also…
“R903.2- Flashing shall be installed in a manner that prevents moisture from entering the wall and roof through joints… … and other roof penetrations.”
It has to prevent moisture intrusion and these are installed incorrectly. But I agree with Jim and Harry, I wouldn’t cite the code, just say it’s wrong, it may leak and recommend correction by a qualified contractor.
