By nature, mobile homes flex and move a lot. Watch
for moisture penetration points, decay spots, loose
tie down straps (mobile homes are suppose to be tied down),
particle board flooring (swells and falls apart), delaminating
siding (inferior product), poor plumbing fixtures, slopes
in the floor, leaning blocks under the foundation, poor
drainage, cheap roofing materials, caulking instead of
flashing, damaged skirting materials, doors out of square,
No access to the attic area, mildew and mold behind
wall paper and loose wall panels, armature porch add-ons,
and Polybutylene Piping, insulation falling down under the
foundation, duct laying on the ground and damaged,
moisture stains painted over, sags in the roof-attic
structure, poor venting, humps in the floor where they
join together, fixtures falling off the wall with a little
pressure.
And if the old exterior siding is metal, be aware that the
metal is made of the same magnesum that they put into
fire crackers to make them explode… and the time span
to escape from a burning mobile home is just a couple minutes,
if your lucky enough not to die from the deadly smoke…
BTW… mobile homes are the only real estate that has a blue book
of devaluation, just like an automobile. They loose value
each year, no matter how you fix them up.
Varmints love to live in the joist systems after the insulation
starts to fall off. The toilets will come out of the particle
board floor if you lean over a little too much. If the toilet
runs over or the dog pisses on the floor, the particle board
will hold the odor for a long time.
The laminating process of all the cheap materials in a mobile
home let go of gases over the years and the smell of glue
and chemicals lingers for a long time in some cases. The
trim is always popping off everywhere. The studs are narrow
and the ceiling materials sag a lot. The flooring creaks and
gets loose after a while.
I will stop for now… you get the picture… list everything.!
Always remind your client that mobile homes are not built
to the same standards as normal residential construction
in most cases… So they will not be surprised with all the
little things that keep needing fixed after they buy their
dream home. :shock:
