These downspouts are discharging water on the deck above the garage. Other houses in the neighbourhood has the same arrangement. Does anyone know if there is some type of a drainage system for the water to properly drain?
I could see some gravel and something that looked similar to that blue rigid foam insulation through the gap between the planks.
