draw inspection form question...
hey guys,
i am uploading a picture of the draw inspection report form that i am going to use for this company.
my question is, what do the second and third columns figures mean ?
the columns in question are Total and % ??
are they samples of previous data ?
i thought when they asked for percentage of work done, that would be just it…, a percentage on each item.
but now this has me wondering.
thanks for your help
kevin rea
Each completed item represents a portion of the total completion of the build.
When Stage 1 is 100% complete, this represents 23% completion of the entire project. Stages are broken down into line items so that portions of other stages can be calculated, even if a particular stage has not been completed.
Does that make sense?
hi Jeff.,
it kind of makes sense.
so, under each line item, do i put the percentage of completion up to 100%, or only up to the number quoted in the Total or % column ?
like on line one, for site preparation, the first column is 4 and then the second column under % is also 4., does that mean that site preparation is 100 % complete ?
let’s take another line…
under floor framing/slab/basement: the first column is 23 and the second column is 5, does that mean that it is 21% complete ?
kevin
If Site Prep is 100% complete, that is the percentage you enter into column 1 (100%). This makes the total job completion 4%.
Now lets say (for example) these items are also 100% complete;
Windows
Rough-in HVAC
Drywall/plaster
Counter tops
Obviously, other items would need to be completed in order to have these, but this is just an example.
100% of Site Prep = 4%
100% of Windows = 4%
100% of Rough-in HVAC = 1%
100% of Drywall/plaster = 3%
100% of Counter tops = 1%
Making the total job completion 13%
Now let’s add bits and peices;
50% of OS Wall Framing = 3-1/2%
50% of IS Wall Framing = 3%
Typically, round numbers are fine, so you would add another 7% bringing the total job completion to 20%
It’s really simple once it clicks.
jeff,
so, in the column number 1 , that is now blank,
would i be entering the actual percentage completion for that item such as IS Doors, 70 % , for 70% done ?
kevin
That’s correct.
They’re looking for the percentage complete at each particular line item, so they can pay on that item.
For instance, if the drywall budget is $35,000, and it is 70% complete (based on your input), they will pay $24,500.
thanks for your help Jeff.
kevin
