Ok so here, inside the basement before going outside, no it’s not about a supposed need 4 better drainage, no adding soil up to the ROOF and sloping it away won’t fix the stupid leaks, but go ahead n try, NO… an interior drainage system would not fix, repair, seal the exterior openings that allow the stupid water in on floor but if you wanna spend $10,000- 25,000 on that dumb crap go right ahead
Outside 2 vid’s… egress window area, can’t yet determine IF there is an ext-crack or cracked parging in block wall in this area OR near the corner (next video)… it’s like 10 degrees or whatever now so a water test when it gets a lil warmer will determine those possibilities
corner, mortar deteriorated n like i said it’s possible there may be an ext-crack in wall, efflorescence on bottom blocks inside so…
now if i was an interior system scammer, i would have told them several things/lies, misrepresentations such as, lol , You need our interior drainage system and sump pump because you have a hydrostatic pressure problem under the floor around perimeter, or, your exterior drain tiles are clogged and so we can install our inside drainage system INSTEAD of digging up the outside which would cost you $35,000+, CRAP like that… yeah part of their game is popping UP the cost of exterior waterproofing and making it seem like it’s sooo expensive and that you’d need a backhoe to do it and all the crap, grass, bushes, concrete etc will get all screwed up, LIES… yeah they often disparage ext-waterproofing
