Originally Posted By: justin watts This post was automatically imported from our archived forum.
Hello everybody…
I was curious, does anyone shut down the main, before removing the inside cover? I would think this would increase safety.... even though we shouldn't be turning off the power temporarily.
I know one inspector that wear special rubber gloves, with a full face shield when removing a panel, (afraid of sparks) and even steps on a rubber mat before opening any panel. I guess you can never be too safe!
It seems to me that the majority of NEC violations are double taps on breakers, what do you guys think?
If anyone else has any safety tips, let me know.... I don't want to get zapped!
Take Care,
Justin Watts
Originally Posted By: jedwards This post was automatically imported from our archived forum.
This is the main panel of a house I did recently. This house is a foreclosure that the client is buying as a fixer-upper/rental investment. To give you a basic idea about the condition of the house, it was 1400 square feet, and had been unoccupied for many months, so all utilities were disconnected at the time of inspection-- and still, the finished report had 28 pages and 73 pictures. This house would make a great final exam.(Recommended specialist evaluations for everything.)
Since the power was off, no problem throwing the main switch. Box is a basic safety-interlock fuse panel; it can't be opened unless the switch handle on the right side is thrown. However, two of the internal levers (the colored-in bits) that are supposed to disconnect the mains terminals from the fuses have come off the bar that operates them. So even with the main switch cut so the box can be opened, the fuse on the left leg is still connected. (Center one doesn't matter since it's single-phase, of course).
And as others have said, be EXTREMELY careful removing the cover ... especially with FPE panels ...
-- Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
