In new housing with plastic pex piping is it okay to ground the Service panel to the gas line as it exits the house?(normal Service grounding is to a copper water supply line)
NO !
Ah. Now I see…
Are you sure your not missing the fact that the pipe was just bonded, and the grounding rod is at the panel or service meter?
