I know that exterior residential doors should be opened inside and commercial doors outside…but does a residential main entrance door which opens outside with hinges also on the outside should be changed…?
What are the requirements?
P.S Not opening over the stairs, it does have resting area and is also protected with a shade…so no snow accumulation. The only concern is what if someone decides to take the main entrance door out by working on the hinges…?
Did you check the hinges? They make security hinges for just this purpose. My mom has them for the French doors opening out onto the patio. It is only an issue if they are regular hinges without the security pins.
check the hinges…I just installed a jeld wen that had a security detail worked
right into the hinges…you could remove all 3 pins completely and still not remove the door…not all hinges are the same.
Heck, most regular hinges can be made to work. Many have the screw holes on the two plates that line up. Take both screws out. Replace one of the screws with a nail that sticks out 1/4 inch and into the other hole when the door is closed.
