Around here that would be in Liquid tight conduit.(not romex)
Yes call it out on the non approved hangers (what is that? zip ties)
Looks like they never sealed the opening either.
Recommend a certified electrician make corrections
Hi Dave, It looks to me like the Romex is “punched” through the siding and routed behind the service entrance and disappears. Did they make a turn and go under ground or did they go up to a disconnect? Is the Romex rated for outside/burial? I would have thought that the wire should stay inside the house and then pass directly into a disconnect box and then to an approved outside wiring method. The cable hangers on the inside look like phone wire hangers.
Dick
Hang on just a minute here .
Could those just be phone lines?
If so just right them up as needing a drip loop and silicone sealant at the external entry point
Yeah I know.
Thats why I asked as it looks like it, but I did not scrutinize your first post.
If correct the yellow jacket stuff is underground telco drop line.
Bet they have more than one phone number.
Great catch Robert!! That makes complete sense now. The Telco demark is on the left side of the service drop and those inside hangers are telco cable hangers. This pic should be on a test somewhere…
