I inspected a home that had a recalled federal pacific panel installed
in a 1989 home.There were no visual defects,but if a breaker was to go bad they would have to change the entire panel.Can anyone lead me to the re-call information on these panels?
Jeff-The electrician said the panel does not exsist any more.What happens in they burn/or damage a breaker.The electrician said they no longer have the type they would need?
Thats the type of panel Stab-lock.My customer has concerns about this panel.I have noted no visual defects and proper awg conductor,no arcing present but they still insist the seller replace the panel.
If they want it replaced that is between them and the seller. In either case it doesn’t cost that much to have that done. $100.00 to 200.00 for supplies & labor. A good electrician should be able to change over the panel in under 3-4 hours unless there are some major problems with the original wiring.
http://www.schneider-electric.ca/www/en/history/html/19451968.htm
These panels are still being manufactured and used in Canada.
I do not know if they are much different then what you have in the USA .
I think that around 50% of the homes I inspect have them .
They are not a big concern and I have seen no more difficulties then I see in other installations .
Roy Cooke sr. Royshomeinspection.com
Square D Company
200 Amp 30/40 Main Breaker Panel Value Pack
Item #: 39537 Model: HOMVP9**$119.00
**30 space, 40 circuit
Contains: (1) HOM3040M200TC panel, (1) equipment ground bar, (6) 15AMP and (6) 20AMP single pole, (1) 30 AMP and (1) 50AMP two pole circuit breakers
For indoor use
GE
32 Space, 200 Amp, Main Breaker Load Center Contractor Kit
Item #: 103821 Model: TM3220CCU2K**$110.00
**Interchanging of GE breakers and load centers with other manufacturer’s products voids GE’s life time warranty
UL listed
200 amp, 32 circuits
Single phase, 3 wire, 120/240/volts AC
Includes the following 1" breakers: ten single pole 20 amp, one double pole 30 amp and one double pole 50 amp
Uses TGK32 ground bar kit if necessary
Factory installed main breaker
Cutler-Hammer
200 Amp Indoor Load Center Value Pack
Item #: 101588 Model: BR3040B200V**$99.00
**30 space, 40 circuits
Type BW 10kAIC breaker
Aluminum bus
NEMA 1- indoor use
Includes BR3040B200 loadcenter, With 5-BR120 and 1-BR230 branch breakers
I’m not talking about an upgrade just a replace with the same amp, with no special changes. Just to swap out the old stab loc with newer system. As long as everything else was up to snuff. Electricans don’t get $200.00 an hour. Do they??? It shouldn’t take an Electrican all day to do a swap-out.
Jason…Electrical Contractors have to make MONEY also…we are not concerned about the “COST” of material…we are concerned about being PAID for our SKILL, TIME and QUALITY…not just the cost of material and yes we are going to mark that up also on “Service Changes”
lol…We are not cheap fella…Are you telling me a HI doing a 3-4 hour inspection SHOULD make as much as an electrician doing a 3-4 hour service change…?
What MATERIAL do HI’s have invested in the JOB versus the Electrician for such LITTLE margin of profit.
I have to admit, I have not priced out what the contractors would charge for something like this for about 3 years. So there is a good chance I am way off.
It is not a Per HOUR thing Jason…Service Changes atleast to ME are quoted…not time and material jobs.
Also I would be doing a client an INJUSTICE if I switched out a 100A Federal Pacific with a 100A Square D…just does not seem RIGHT in my mind…but yes if you are speaking of a DIRECT switch off…then you can knock about $ 200.00 off of it…
No you are fine my brother…but the cost of Service Changes are GOING up for many reasons…Labor is higher and Burdon % is higher ( about 9% ) and well it is rough to say but about every year it goes up about $ 100- 150.00 in cost adjustments…
anyway…you are fine my fine fella…again everywhere is different as well and prices to change…the 800-1200 is about average.
