Fire Damage
Originally Posted By: Steven Brewster
I am looking for a standard that determines when framing members can be utilized or should be replaced after a fire. I inspected this attic and the framing was pretty charred in some areas. Any help would be appreciated.
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P1040665.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P1040664.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P1040673.JPG ]
Originally Posted By: jpope
The “rule of thumb” is 1/4 inch. Those things are toast - literally. Replacements are needed. . .
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
What he said!
Originally Posted By: bking
Its hard to believe anyone would leave those and that anyone would have paid for that work. icon_eek.gif
www.BAKingHomeInspections.com
Originally Posted By: mboyett
No ridge board or gusset plates?
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
Thanks guys, those were my thoughts as well. I just could not find any concrete guidelines to make an objective conclusion. I have heard the 1/4" rule (if you can insert a ice pick 1/4" it should be replaced) but could not find it documented.
This was an older home, probably 1930-1940. This poor guy called me to evaluate after looking in the attic 5 months after he purchased the home (should have had an inspection). It was an owner finance and they paid 10K down. They were told by the seller that the home was in tip top condition with no problems. You can bet this will end up in a court room!
I really don't understand why everyone that purchases a home does not have it inspected. This guy learned a expensive lesson.
Originally Posted By: Jay Moge
oh yeah, there toast. they should either be replaced immediatly, or scrapped realy good with a butter knife over the trash can, buttered, then replaced. icon_cool.gif
Originally Posted By: rwand1
Charred wood will also have a lower ignition point than fresh lumber. Replace, replace, replace.
Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
NACHI Member
Registered Home Inspector (OAHI)
http://www.raymondwand.ca
